- This topic has 0개 답변, 1명 참여, and was last updated 15 years, 3 months 전에 by
인베인. This post has been viewed 924 times
INDEX
1. bluetooth 환경 구축하기
2. bluetooth Mouse 설정 방법
3. bluetooth Headphone 설정 방법
4. bluetooth용을 위한 리눅스 음악 S/W사용법
5. 블루투스 리모컨 사용하기!---------------------------------- 1. bluetooth 환경 구축하기 --------------------------------------------------------------------------
1. Linux kernel 빌드시에 아래의 bluetooth관련 피쳐들이 enable되어 있어야 한다.
Fedora11배포판의 리눅스 커널에는 아래의 피쳐들이 기본으로 포함되어 있다.#> make menuconfig
Networking --->
<*> bluetooth subsystem support --->--- bluetooth subsystem support
L2CAP protocol support
SCO links support
RFCOMM protocol support
[*] RFCOMM TTY support
BNEP protocol support
[*] Multicast filter support
[*] Protocol filter support
HIDP protocol supportbluetooth device drivers --->
HCI USB driver
[*] SCO (voice) support
HCI UART driver
[*] UART (H4) protocol support
[*] BCSP protocol support
[*] Transmit CRC with every BCSP packet
HCI BCM203x USB driver
HCI BPA10x USB driver
HCI BlueFRITZ! USB driver
(The four drivers below are for PCMCIA bluetooth devices and will only
show up if you have also selected PCMCIA support in your kernel.)
HCI DTL1 (PC Card) driver
HCI BT3C (PC Card) driver
HCI BlueCard (PC Card) driver
HCI UART (PC Card) device driver
(The driver below is intended for HCI Emulation software.)
HCI VHCI (Virtual HCI device) driver(Move back three levels to Device Drives and then check if USB is
enabled. This is required if you use a bluetooth dongle, which are mostly USB
based.)
USB support ---><*> Support for Host-side USB
--- USB Host Controller Drivers
EHCI HCD (USB 2.0) support
[ ] Full speed ISO transactions (EXPERIMENTAL)
[ ] Root Hub Transaction Translators (EXPERIMENTAL)
<*> OHCI HCD support
<*> UHCI HCD (most Intel and VIA) support
< > SL811HS HCD support--------------------------------------------------------------------------
2. rpm 명령어를 실행하여 필요한 패키지 설치여부를 확인한다.
invain-f11#> yum install bluez-* bluetooth-alsa pulseaudio-module-* alsa* mplayer* pavucontrol blueman----------------------------------2. bluetooth Mouse 설정 방법 --------------------------------------------------------------------------
1. 블루투스 장치(MS 5000 Mouse)의 MAC Address 를 검색해야합니다.
(검색된 주소는 기억합니다.)
invain-f11#> hcitool scan
Scanning ...
00:1E:7D:56:21:99 invain-SPH-W3300
00:17:C3:08:FB:8C soogik-Ever2. bluetooth configuration file을 수정해야합니다.
invain-f11#> sudo gedit /etc/bluetooth/hcid.conf
device 00:12:5A:57:B8:4A{
name "Microsoft bluetooth Mouse 5000"
}3. bluetooth를 재시작합니다.
invain-f11#> sudo /etc/init.d/bluetooth restart4. 마우스 바닥에 있는 페어링 스위치를 누른후 아래의 명령을 실행합니다.
invain-f11#> sudo hidd --search5. 아래 명령을 실행후에 파일 내용중 HIDD_ENABLED 값을 0에서 1로 바꿉니다.
invain-f11#> sudo gedit /etc/default/bluetooth---------------------------------- 3 bluetooth Headphone 설정 방법 --------------------------------------------------------------------------
1. 이제, 블루투스 이어폰으로 mp3, wav 음악 파일을 듣도록 해보자.
음악 소프트웨어별로 블루투스를 사용하기 위한 설정방법에 대한 설명이 있다.invain$> hcitool scan
Scanning ...
9A:51:41:D3:15:00 S380Kㅡinvain
00:18:13:E7:8D:05 HBH-DS970(bluetooth headphone)invain$> vi ~/.asoundrc ( or /etc/asound.conf )
# Change /etc/asound.conf
pcm.bluetooth {
type bluetooth
device "00:18:13:E7:8D:05"
profile "auto"
invain$>
invain$> hciconfig -a
hci0: Type: USB
BD Address: 00:30:91:40:1B:47 ACL MTU: 384:8 SCO MTU: 64:8
UP RUNNING PSCAN ISCAN
RX bytes:160080 acl:172 sco:0 events:21776 errors:0
TX bytes:13253771 acl:42862 sco:0 commands:93 errors:0
Features: 0xff 0xff 0x8f 0xfe 0x9b 0xf9 0x00 0x80
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH HOLD SNIFF PARK
Link mode: SLAVE ACCEPT
Class: 0x0a210c
Service Classes: Networking, Capturing
Device Class: Computer, Laptop
HCI Ver: 2.0 (0x3) HCI Rev: 0x7a6 LMP Ver: 2.0 (0x3) LMP Subver: 0x7a6
Manufacturer: Cambridge Silicon Radio (10)2. Bluetoooth 사운드 모듈을 PulseAudio에 추가하기
invain$> vi /etc/bluetooth.sh
pactl load-module module-alsa-sink device="bluetooth"
pactl load-module module-alsa-source device="bluetooth"
invain$> chmdod 755 /etc/bluetooth.sh
invain$> pulseaudio -k ( Unloading bluetooth sound module from alsa )
invain$> pulseaudio -Dv
invain$> pavucontrol ( Pulse Audio Volume Manager - Output tab - Select bluetooth Stereo)3. bluetooth HeadPhone 의 페어링
bluetooth-properties(gnome-bluetooth or blueman-manager(blueman) 사용하기
#> blueman-manager ( Gnome Foot - System - Preference - Blueman bluetooth Manager)4. 이제 리눅스에서 플레이하는 음악을 블루투스 이어폰을 통해 들리게 된다.
---------------------------------- 4 bluetooth용을 위한 리눅스 음악 S/W사용법 --------------------------------------------------------------------------
리눅스 전체에 블루투스 이어폰을 셋팅하지 않고, 특정 음악 프로그램의 옵션을 이용하여 플레이를 할수도 있다.
http://wiki.bluez.org/wiki/HOWTO/AudioDevices
http://blueman-project.org/invain$>
invain$> aplay -D bluetooth/usr/share/sounds/card_shuffle.wav
invain$> mplayer -ao alsa:device=bluetooth/usr/share/sounds/card_shuffle.wav
invain$> mplayer -ao alsa:device=bluetooth/usr/share/sounds/toeic18.mp3
invain$> mplayer -ao alsa:device=bluetooth mms://118.223.168.32/efm------------- 5. 블루투스 리모컨 사용하기!--------
이 팁은 생각보다 간단합니다. 우분투 8.04 이상의 배포판에서는
원래는 기본적으로 되는게 정상이라고 합니다만, 안될경우엔 아래 팁을 이용하세요.1. 터미널에서
sudo gedit /etc/modules
를 입력합니다.
2. 그러면 나오는 창 맨 아랫 줄에
uinput
을 추가합니다.
3. 저장 후 재부팅하거나 아니면 아래 명령어를 입력합니다.(재부팅을 권장합니다.)
sudo modprobe uninput
4. 이제 블루투스 헤드폰을 연결하여 조작해봅니다. 윈도우즈와는 달리,
대부분의 프로그램(리듬박스, 엑자일, 아마록 등등)에서 이 리모컨 기능을
사용할 수 있습니다.(리듬박스와 엑자일은 테스트해봤습니다.)그러나 이 것도 조금은 불안정합니다. 비교적 최신 블루투스 헤드폰이라면
다 되는 것 같은데 제가 보유한 블루투스 헤드셋 중 BTR-1000은 기능이
폭주를 일으켰고, iBluon은 정상적으로 되었습니다.End of line.
