- This topic has 1개 답변, 2명 참여, and was last updated 15 years, 3 months 전에 by
野石施佑. This post has been viewed 1800 times
Nviadia 전용 드라이버로 설치후에 Dual Monitor환경에서 우측의 모니터를
90도 회전하여 사용하고자 할경우에는 /etc/X11/xorg.conf 파일을 Xwindows
에서 nvidia-settings 명령으로 만들 경우 우측의 모니터만 90도 회전할수가
없어서 2가지의 방법이 있다.방법1) nvidia-settings명령으로 dual monitor 설정후에
xorg.conf파일을 열어서 Xinerama을 기능을 제거후, gnome-terminal에서
fc6#> xrandar right 명령을 이용한다.방법2) Device Section을 각기 2개로 작성한후에 오른쪽 모니터에 해당하는
Device Section에 Option "Rotate" "CCW" 을 추가하도록 한다. (권장)# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 1.0 (invain , leemgs.at.gmail.com) Thu Jun 5 09:26:53 UTC 2008# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorgSection "ServerLayout"
Identifier "Default Layout"
Screen 0 "Screen0" 0 0
EndSectionSection "Module"
Load "glx"
EndSectionSection "ServerFlags"
Option "Xinerama" "0"
EndSectionSection "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSectionSection "Monitor"
Identifier "Configured Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "CRT-0"
HorizSync 30.0 - 81.0
VertRefresh 56.0 - 75.0
EndSectionSection "Device"
Identifier "Configured Video Device"
Driver "nvidia"
Option "NoLogo" "True"
Identifier "Videocard0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce "
EndSectionSection "Screen"
Identifier "Default Screen"
Device "Configured Video Device"
Monitor "Configured Monitor"
DefaultDepth 24
# Removed Option "metamodes" "CRT: nvidia-auto-select +0+0, DFP: nvidia-auto-select +0+0"
# Removed Option "metamodes" "CRT: 1280x1024 +0+0, DFP: 1280x1024 +1280+0"
# Removed Option "TwinViewXineramaInfoOrder" "CRT-0"
# Removed Option "TwinViewXineramaInfoOrder" "DFP-0"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
Option "TwinView" "1"
Option "metamodes" "CRT: 1280x1024 +0+1024, DFP: 1280x1024 +0+0"
EndSection아래는 nvidia 그래픽카드에서 작성된 xorg.conf파일이다.
