yum 을 이용한 Upgrade
게시판 Tech/Tip yum 을 이용한 Upgrade
  • This topic has 0개 답변, 1명 참여, and was last updated 14 years, 1 month 전에 by 태랑. This post has been viewed 2317 times
  • #12165
    페도라 프로젝트 위키를 참조하였습니다.
    https://fedoraproject.org/wiki/YumUpgradeFaq#Fedora_12_-.3E_Fedora_13
    Fedora 13 -> Fedora 14
    First install the new fedora 14 gpg key. You may wish to verify this package against https://fedoraproject.org/keys and the fedora ssl certificate.
    rpm --import https://fedoraproject.org/static/97A1071F.txt
    Upgrade all packages with
    yum update yum
    yum clean all
    yum --releasever=14 distro-sync
    • If using VirtualBox from the Oracle repository, you must remove
      the VirtualBox-3.1 package before upgrading. After the upgrade is
      finished, install VirtualBox-3.2.
    Fedora 12 -> Fedora 13
    First install the new fedora 13 gpg key. You may wish to verify this package against https://fedoraproject.org/keys and the fedora ssl certificate.
    rpm --import https://fedoraproject.org/static/E8E40FDE.txt
    yum update yum
    yum clean all
    yum --releasever=13 distro-sync
    • Testing shows that upgrading within X will cause X to hang when installing `bitmap-fonts-compat`, but it can be done anyway by making sure that `bitmap-fonts-compat` is the last package to update ... YMMV.
    • Intel video no longer works without Kernel Mode Setting (KMS).
      You must remove 'nomodeset' from your /etc/grub.conf kernel command
      line, if present.
    • nVidia video no longer works without kernel mode Setting
      (KMS). You must remove 'nomodeset' from your /etc/grub.conf kernel
      command line, if present.
    • It may be necessary to run "db_recover -h /var/lib/ldap/ ; chown ldap:ldap /var/lib/ldap/*" once in order for slapd to start.
오라클 설치에 필요한 램용량은 어떻게 되나요?
인사 하고 글쓰고 갑니다.
[TIP] LXDE running obenbox fails to open "Applications" menu
페도라의 이전 버전을 받고 싶습니다.
가입했습니다
ai 언어 모델 시험을 위한 ollama 설치 및 사용법
메리 크리스마스
/etc/log/messages 의 기록
