- This topic has 2개 답변, 3명 참여, and was last updated 14 years, 6 months 전에 by
딱털서어. This post has been viewed 570 times
리눅스를 처음사용해 보는 초보 유저 입니다.
어찌어찌 여기에서 도움을 얻어 fedora12 설치까지 완료 햇는데.. 끝이 아니더군요..무선인터넷에서 막혀서 여기서 찾아봤더니
답변들이 있었는데 무슨뜻인지 정확히 이해를 못하겠습니다..
답변들중에 lspci lsmod cat/proc/cpuinfo cat/proc/meminfo uname -a ifconfig iwconfig 정보를 올리면 도움말 주시겠다는 분(인베인이라는 아이디를쓰시는분) 계셔서 저도 정보 올리면 어떻게 될까하고 정보를 올려봅니다.
정말 리눅스를 모르는 초보인데 도와주세요ㅠ_ㅠ
1.[ohjshjsh@ohjshjsh ~]$ lspci
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
00:02.1 Display controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
00:1a.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03)
00:1a.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03)
00:1a.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 03)
00:1c.3 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 4 (rev 03)
00:1c.5 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 6 (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93)
00:1f.0 ISA bridge: Intel Corporation ICH9M LPC Interface Controller (rev 03)
00:1f.2 IDE interface: Intel Corporation ICH9M/M-E 2 port SATA IDE Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
00:1f.5 IDE interface: Intel Corporation ICH9M/M-E 2 port SATA IDE Controller (rev 03)
04:00.0 Network controller: Broadcom Corporation BCM4322 802.11a/b/g/n Wireless LAN Controller (rev 01)
08:00.0 Ethernet controller: Broadcom Corporation NetLink BCM5784M Gigabit Ethernet PCIe (rev 10)
09:01.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller (rev 05)
09:01.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 22)
09:01.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 12)
09:01.3 System peripheral: Ricoh Co Ltd xD-Picture Card Controller (rev 12)2.[ohjshjsh@ohjshjsh ~]$ lsmod
Module Size Used by
fuse 62048 2
sunrpc 191864 1
ip6t_REJECT 5856 2
nf_conntrack_ipv6 21880 2
ip6table_filter 4016 1
ip6_tables 19664 1 ip6table_filter
ipv6 298864 24 ip6t_REJECT,nf_conntrack_ipv6
cpufreq_ondemand 7824 2
acpi_cpufreq 10528 0
freq_table 4864 2 cpufreq_ondemand,acpi_cpufreq
dm_multipath 17304 0
uinput 9248 0
snd_hda_codec_intelhdmi 14912 1
snd_hda_codec_idt 66800 1
b43 127432 0
mac80211 181512 1 b43
firewire_ohci 23348 0
cfg80211 87800 2 b43,mac80211
firewire_core 47880 1 firewire_ohci
snd_hda_intel 30344 2
ssb 43600 1 b43
snd_hda_codec 72832 3 snd_hda_codec_intelhdmi,snd_hda_codec_idt,snd_hda_intel
snd_hwdep 9224 1 snd_hda_codec
snd_seq 58080 0
sdhci_pci 9008 0
iTCO_wdt 13008 0
sdhci 20676 1 sdhci_pci
snd_seq_device 7620 1 snd_seq
iTCO_vendor_support 3588 1 iTCO_wdt
mmc_core 58832 1 sdhci
snd_pcm 83144 2 snd_hda_intel,snd_hda_codec
i2c_i801 12800 0
joydev 11984 0
uvcvideo 58972 0
videodev 36160 1 uvcvideo
v4l1_compat 14052 2 uvcvideo,videodev
v4l2_compat_ioctl32 10736 1 videodev
tg3 105476 0
wmi 7280 0
crc_itu_t 2080 1 firewire_core
snd_timer 22608 2 snd_seq,snd_pcm
snd 67592 13 snd_hda_codec_intelhdmi,snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_seq,snd_seq_device,snd_pcm,snd_timer
soundcore 7328 1 snd
snd_page_alloc 9568 2 snd_hda_intel,snd_pcm
dell_laptop 5800 0
rfkill 20488 2 cfg80211,dell_laptop
dcdbas 10800 1 dell_laptop
i915 219952 2
drm_kms_helper 25360 1 i915
drm 171168 3 i915,drm_kms_helper
i2c_algo_bit 6020 1 i915
i2c_core 28608 5 i2c_i801,videodev,i915,drm,i2c_algo_bit
video 23476 1 i915
output 3360 1 video3.[root@ohjshjsh proc]# cat cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 23
model name : Intel(R) Core(TM)2 Duo CPU T6400 @ 2.00GHz
stepping : 10
cpu MHz : 1200.000
cache size : 2048 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good pni dtes64 monitor ds_cpl est tm2 ssse3 cx16 xtpr pdcm sse4_1 xsave lahf_lm
bogomips : 3990.07
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:processor : 1
cpu family : 6
model : 23
stepping : 10
cpu MHz : 1200.000
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 3990.43
clflush size : 64
power management:4.[root@ohjshjsh proc]# cat meminfo
MemTotal: 4019744 kB
MemFree: 3437004 kB
Buffers: 22440 kB
Cached: 209428 kB
SwapCached: 0 kB
Active: 220864 kB
Inactive: 158668 kB
Active(anon): 175840 kB
Inactive(anon): 156 kB
Active(file): 45024 kB
Inactive(file): 158512 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 2097144 kB
SwapFree: 2097144 kB
Dirty: 24 kB
Writeback: 0 kB
AnonPages: 147764 kB
Mapped: 62984 kB
Slab: 56840 kB
SReclaimable: 24880 kB
SUnreclaim: 31960 kB
PageTables: 28480 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 4107016 kB
Committed_AS: 590564 kB
VmallocTotal: 34359738367 kB
VmallocUsed: 573852 kB
VmallocChunk: 34359147827 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
DirectMap4k: 10240 kB
DirectMap2M: 4145152 kB5.[root@ohjshjsh home]# uname -a
Linux ohjshjsh 2.6.31.5-127.fc12.x86_64 #1 SMP Sat Nov 7 21:11:14 EST 2009 x86_64 x86_64 x86_64 GNU/Linux6.[root@ohjshjsh home]# ifconfig
eth0 Link encap:Ethernet HWaddr 00:22:19:E4:B9:03
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:17lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:480 (480.0 b) TX bytes:480 (480.0 b)7.[root@ohjshjsh home]# iwconfig
lo no wireless extensions.eth0 no wireless extensions.
안녕하세요 ^ ^~
