에코 서버, 에코 클라이언트 소스 입니다
게시판 질문게시판 에코 서버, 에코 클라이언트 소스 입니다
  • This topic has 0개 답변, 1명 참여, and was last updated 14 years, 6 months 전에 by 쌈구. This post has been viewed 430 times
  • #13131
    쌈구
      게시글21 댓글32 총합53
    @ssamgu1
    <에코 서버>
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    #include <unistd.h>
    #include <arpa/inet.h>
    #include <sys/socket.h>
    #define BUF_SIZE 1024
    void error_handling(char *message);
    int main(int argc, char *argv[])
        int serv_sock, clnt_sock;
        char message[BUF_SIZE];
        int str_len, i;
        struct sockaddr_in serv_adr;
        struct sockaddr_in clnt_adr;
        socklen_t clnt_adr_sz;
        if(argc!=2) {
            printf("Usage : %s <port>\n", argv[0]);
            exit(1);
        serv_sock=socket(PF_INET, SOCK_STREAM, 0);
        if(serv_sock==-1)
            error_handling("socket() error");
        memset(&serv_adr, 0, sizeof(serv_adr));
        serv_adr.sin_family=AF_INET;
        serv_adr.sin_addr.s_addr=htonl(INADDR_ANY);
        serv_adr.sin_port=htons(atoi(argv[1]));
        if(bind(serv_sock, (struct sockaddr*)&serv_adr, sizeof(serv_adr))==-1)
            error_handling("bind() error");
        if(listen(serv_sock, 5)==-1)
            error_handling("listen() error");
        clnt_adr_sz=sizeof(clnt_adr);
        for(i=0; i<5; i++)
            clnt_sock=accept(serv_sock, (struct sockaddr*)&clnt_adr, &clnt_adr_sz);
            if(clnt_sock==-1)
                error_handling("accept() error");
            else
                printf("Connected client %d \n", i+1);
            while((str_len=read(clnt_sock, message, BUF_SIZE))!=0)
                write(clnt_sock, message, str_len);
            close(clnt_sock);
        close(serv_sock);
        return 0;
        fputs(message, stderr);
        fputc('\n', stderr);
        exit(1);
    <에코 클라이언트>
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    #include <unistd.h>
        int sock;
        int str_len;
        if(argc!=3) {
            printf("Usage : %s <IP> <port>\n", argv[0]);
            exit(1);
        if(sock==-1)
        serv_adr.sin_addr.s_addr=inet_addr(argv[1]);
        serv_adr.sin_port=htons(atoi(argv[2]));
        if(connect(sock, (struct sockaddr*)&serv_adr, sizeof(serv_adr))==-1)
            error_handling("connect() error!");
        else
            puts("Connected...........");
        while(1)
            fputs("Input message(Q to quit): ", stdout);
            fgets(message, BUF_SIZE, stdin);
            if(!strcmp(message,"q\n") || !strcmp(message,"Q\n"))
                break;
            write(sock, message, strlen(message));
            str_len=read(sock, message, BUF_SIZE-1);
            message[str_len]=0;
            printf("Message from server: %s", message);
        close(sock);
        return 0;
        exit(1);
    소스가 문젠인거가요??ㅠ.ㅠ
    안뇽하세요~잘부탁드립니다.
    대학생 입니다.ㅋㅋㅋ
새로운 한주 입니다
페도라 12를 설치를 했는데..
'restart|다시 시작'하면 컴퓨터가 반복적으로 꺼졌다 켜졌다합니다.
안녕하세요!
[tip - tech] 페도라에서 본딩 관련 설정과 사용
chkconfig관련해서 질문좀..
[tip-tech] 서버 전원 조작
가입인사 올립니다.
[Tip]로그인 시 Nvidia 환경 설정 불러오는 방법입니다.
