- This topic has 4개 답변, 2명 참여, and was last updated 14 years, 4 months 전에 by
러브썬. This post has been viewed 3866 times
1. Checking available swap space requirements
-> warning
swap을 파티션시 4G 잡았었습니다.
Expected result: 4016MB
Actual Result: 3999MB
Check complete. The overall result of this check is:Failed <<<<
Problem: The system does not have the required swap space.
Recommendation: Make more swap space available to perform the install.
2. Checking Network Configuraiton requirements
-> Not executed
: 현재 네트워크 설정 IP 안 해서 그런거 같은데 하는 방법 좀 알려주세요.
유동IP 를 사용하고 있습니다.
네트워크 설정 부분도..
