fedofa14 그래픽 설정 확인 방법을 모르겠어요~ㅜㅜ
게시판 질문게시판 fedofa14 그래픽 설정 확인 방법을 모르겠어요~ㅜㅜ
  • This topic has 0개 답변, 1명 참여, and was last updated 12 years, 11 months 전에 by kjs1728. This post has been viewed 350 times
  • #13441
    kjs1728
      게시글1 댓글0 총합1
    @kjs1728
    fedora14를 깔고 그래픽 카드를 깔았습니다.
    제 컴은 레노버 X61 이구요~
    그래픽은 intel GM965 Express 칩입니다.
    여기저기 찾아보고 우여곡절끝에 깔긴 했는데 잘 깔았는지 확인을 할 수가 없네요~ㅜㅜ
    일단 xorg.conf에서 확인 해야하는 것 같아 봤는데 모르겠네요~ㅜㅜ
    아래는 xorg.conf 내용입니다.
    Section "ServerLayout"
        Identifier     "X.org Configured"
        Screen      0  "Screen0" 0 0
        InputDevice    "Mouse0" "CorePointer"
        InputDevice    "Keyboard0" "CoreKeyboard"
    EndSection
    Section "Files"
        ModulePath   "/usr/lib/xorg/modules"
        FontPath     "catalogue:/etc/X11/fontpath.d"
        FontPath     "built-ins"
    EndSection
    Section "Module"
        Load  "extmod"
        Load  "dri2"
        Load  "dbe"
        Load  "record"
        Load  "glx"
        Load  "dri"
    EndSection
    Section "InputDevice"
        Identifier  "Keyboard0"
        Driver      "kbd"
    EndSection
        Identifier  "Mouse0"
        Driver      "mouse"
        Option        "Protocol" "auto"
        Option        "Device" "/dev/input/mice"
        Option        "ZAxisMapping" "4 5 6 7"
    EndSection
    Section "Monitor"
        Identifier   "Monitor0"
        VendorName   "Monitor Vendor"
        ModelName    "Monitor Model"
    EndSection
    Section "Device"
            ### Available Driver options are:-
            ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
            ### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
            ### <percent>: "<f>%"
            ### [arg]: arg optional
            #Option     "NoAccel"                # [<bool>]
            #Option     "SWcursor"               # [<bool>]
            #Option     "ColorKey"               # <i>
            #Option     "CacheLines"             # <i>
            #Option     "Dac6Bit"                # [<bool>]
            #Option     "DRI"                    # [<bool>]
            #Option     "NoDDC"                  # [<bool>]
            #Option     "ShowCache"              # [<bool>]
            #Option     "XvMCSurfaces"           # <i>
            #Option     "PageFlip"               # [<bool>]
        Identifier  "Card0"
        Driver      "intel"
        BusID       "PCI:0:2:0"
    EndSection
    Section "Screen"
        Identifier "Screen0"
        Device     "Card0"
        Monitor    "Monitor0"
        SubSection "Display"
            Viewport   0 0
            Depth     1
        EndSubSection
            Viewport   0 0
            Depth     4
        EndSubSection
            Viewport   0 0
            Depth     8
        EndSubSection
            Viewport   0 0
            Depth     15
        EndSubSection
            Viewport   0 0
            Depth     16
        EndSubSection
            Viewport   0 0
            Depth     24
        EndSubSection
    EndSection
    리눅스 초본데 확인방법 자세히 좀 알려주시면 감사하겠습니다.
irc 하나 만들면 안될까요?
Fedora14에서 SSD 사용에 관해서 질문이 있습니다.
페도라 25 한영키 포함 숫자, 특수문자 전환 대체 어떻게 하나요?????!
페도라16 어제 설치해서 10시간동안 무선 인터넷이 되지 않아 ㅠㅠ
F33 Gnome thermald - earlyoom 적용부분 - KDE 적용상태
Fedora에서 Gnome Nautilus 탭브라우징 하기(찾아보기창에서 열기)
[완료] 웹 서버 변경(이동) 작업 완료
리눅스용 웹서버 "Lighttpd" v1.2.0
CentOS Stream(CentOS 8)
virtualization SW(가상화 소프트웨어) VirtualBox 2.X
