- This topic has 3개 답변, 3명 참여, and was last updated 12 years 전에 by
piglove06. This post has been viewed 3917 times
1. 페도라도 ctrl+alt+t 똑 같습니다.
2. yum 으로 설치하시죠!3. 입력기는 설치하셨습니까? uim, fcitx, ibus, nabi, scim 중 하나를 설치하신 후 환경 설정에서 키잡아 주시면 됩니다.4. 제가 쓰는 vimrc 입니다. 이외 옵션은 알아서 찾아 보십시오." use extended function of vim (no compatible with vi)" set nocompatible" specify encodingset encoding=utf-8" specify file encodingset fileencodings=utf-8,euc-kr,cp949,cp932,euc-jp,shift-jis,big5,latin1,ucs-2le" specify file formatsset fileformats=unix,dos" take backup" if not, specify [ set nobackup ]set nobackup" specify backup directory" set backupdir=~/backup" take 50 search historiesset history=50"파일 형식에 따른 신택스 하이라이팅 켜기sy enable" ignore Caseset ignorecase" distinct Capital if you mix it in search wordsset smartcase" highlights matched words" if not, specify [ set nohlsearch ]set hlsearch" use incremental search" if not, specify [ set noincsearch ]set incsearch" show line number" if not, specify [ set nonumber ]set number" 줄 번호 표시 너비 설정set nuw=3" 화면 우측 하단에 현재 커서의 위치(줄, 칸)을 보여준다.set ruler" Visualize break ( $ ) or tab ( ^I )" set list" highlights parenthesesset showmatch" show color display" if not, specify [ syntax off ]syntax on" change colors for comments if it's set [ syntax on ]highlight Comment ctermfg=LightCyan" wrap lines" if not, specify [ set nowrap ]set wrap"""""""""""""""""""""""""""""""""""""""""""""""""""""""" Color"""""""""""""""""""""""""""""""""""""""""""""""""""""""" 배경 검정색set bg=dark" 색상 밝게 하기set nocompatiblelet colors_name = "classic"hi clearhi Normal guifg=white guibg=blackhi SpecialKey guifg=#666666hi NonText guifg=#666666hi Directory guifg=#99FFFFhi ErrorMsg guifg=#FFFFFF guibg=#FF9999hi IncSearch gui=reversehi Search guifg=#000000 guibg=#999933hi MoreMsg guifg=#99FF99hi LineNr guifg=#FFFF99hi Question guifg=#99FF99hi StatusLine gui=reversehi StatusLineNC gui=reversehi VertSplit gui=reversehi Title guifg=#FF99FFhi Visual gui=reversehi VisualNOS gui=underlinehi WarningMsg guifg=#FF9999hi WildMenu guifg=#000000 guibg=#999933hi Folded guifg=#99FFFF guibg=#666666hi FoldColumn guifg=#99FFFF guibg=#666666hi DiffAdd guibg=#9999FFhi DiffChange guibg=#FF99FFhi DiffDelete term=bold guifg=#9999FF guibg=#99FFFFhi DiffText term=reverse guibg=#FF9999hi Comment term=bold guifg=#99FFFFhi Constant term=underline guifg=#FF99FFhi Special term=bold guifg=#FF9999hi Identifier term=underline guifg=#99FFFFhi Statement term=bold guifg=#FFFF99hi PreProc term=underline guifg=#9999FFhi Type term=underline guifg=#99FF99hi Underlined term=underline gui=underline guifg=#9999FFhi Ignore guifg=#000000hi Error term=reverse guifg=#FFFFFF guibg=#FF9999hi Todo term=standout guifg=#000000 guibg=#999933"""""""""""""""""""""""""""""""""""""""""""""""""""""""" 항상 status 라인을 표시하도록 함set ls=2" status 라인이 어떻게 나오게 할 지 지정set statusline=%<%F%h%m%r%h%w%y\ %{strftime(\"%Y/%m/%d-%H:%M\")}%=\ col:%c%V\ ascii:%b\ pos:%o\ lin:%l\,%L\ %Pset laststatus=2우분투를 왜 저주하시죠! unity를 제외하고는 괜찮은 배포반인데...!페도라를 우분투 처럼 쉽게 생각하시면 큰코 다칠 날이 있을 겁니다.
