페도라22 기준 samba설정방법좀 알려주세요!!
게시판 질문게시판 페도라22 기준 samba설정방법좀 알려주세요!!
  • This topic has 2개 답변, 3명 참여, and was last updated 3 years, 8 months 전에 by
    태랑. This post has been viewed 2533 times
  • #13658
    후라이팬
      게시글1 댓글0 총합1
    @k9706121
    안녕하세요!!
    페도라22 samba 설정방법좀 알려주세요
    swat 설치해서 해볼려고 해도 패키지가 없네요! 부탁드립니다..
    vi /etc/samba/smb.conf
    # This is the main Samba configuration file. For detailed information about the
    # options listed here, refer to the smb.conf(5) manual page. Samba has a huge
    # number of configurable options, most of which are not shown in this example.
    # The Official Samba 3.2.x HOWTO and Reference Guide contains step-by-step
    # guides for installing, configuring, and using Samba:
    # http://www.samba.org/samba/docs/Samba-HOWTO-Collection.pdf
    # The Samba-3 by Example guide has working examples for smb.conf. This guide is
    # generated daily: http://www.samba.org/samba/docs/Samba-Guide.pdf
    # In this file, lines starting with a semicolon (;) or a hash (#) are
    # comments and are ignored. This file uses hashes to denote commentary and
    # semicolons for parts of the file you may wish to configure.
    # Note: Run the "testparm" command after modifying this file to check for basic
    # syntax errors.
    # Security-Enhanced Linux (SELinux) Notes:
    # Turn the samba_domain_controller Boolean on to allow Samba to use the useradd
    # and groupadd family of binaries. Run the following command as the root user to
    # turn this Boolean on:
    # setsebool -P samba_domain_controller on
    # Turn the samba_enable_home_dirs Boolean on if you want to share home
    # directories via Samba. Run the following command as the root user to turn this
    # Boolean on:
    # setsebool -P samba_enable_home_dirs on
    # If you create a new directory, such as a new top-level directory, label it
    # with samba_share_t so that SELinux allows Samba to read and write to it. Do
    # not label system directories, such as /etc/ and /home/, with samba_share_t, as
    # such directories should already have an SELinux label.
    # Run the "ls -ldZ /path/to/directory" command to view the current SELinux
    # label for a given directory.
    # Set SELinux labels only on files and directories you have created. Use the
    # chcon command to temporarily change a label:
    # chcon -t samba_share_t /path/to/directory
    # Changes made via chcon are lost when the file system is relabeled or commands
    # such as restorecon are run.
    # Use the samba_export_all_ro or samba_export_all_rw Boolean to share system
    # directories. To share such directories and only allow read-only permissions:
    # setsebool -P samba_export_all_ro on
    # To share such directories and allow read and write permissions:
    # setsebool -P samba_export_all_rw on
    # To run scripts (preexec/root prexec/print command/...), copy them to the
    # /var/lib/samba/scripts/ directory so that SELinux will allow smbd to run them.
    # Note that if you move the scripts to /var/lib/samba/scripts/, they retain
    # their existing SELinux labels, which may be labels that SELinux does not allow
    # smbd to run. Copying the scripts will result in the correct SELinux labels.
    # Run the "restorecon -R -v /var/lib/samba/scripts" command as the root user to
    # apply the correct SELinux labels to these files.
    #======================= Global Settings =====================================
    [global]
    # ----------------------- Network-Related Options -------------------------
    # workgroup = the Windows NT domain name or workgroup name, for example, MYGROUP.
    # server string = the equivalent of the Windows NT Description field.
    # netbios name = used to specify a server name that is not tied to the hostname.
    # interfaces = used to configure Samba to listen on multiple network interfaces.
    # If you have multiple interfaces, you can use the "interfaces =" option to
    # configure which of those interfaces Samba listens on. Never omit the localhost
    # interface (lo).
    # hosts allow = the hosts allowed to connect. This option can also be used on a
    # per-share basis.
    # hosts deny = the hosts not allowed to connect. This option can also be used on
    # a per-share basis.
    # max protocol = used to define the supported protocol. The default is NT1. You
    # can set it to SMB2 if you want experimental SMB2 support.
            workgroup = WORKGROUP
            server string = Samba Server Version %v
    ;       netbios name = MYSERVER
    ;       interfaces = lo eth0 192.168.12.2/24 192.168.13.2/24
    ;       hosts allow = 127. 192.168.12. 192.168.13.
    ;       max protocol = SMB2
    # --------------------------- Logging Options -----------------------------
    # log file = specify where log files are written to and how they are split.
    # max log size = specify the maximum size log files are allowed to reach. Log
    # files are rotated when they reach the size specified with "max log size".
            # log files split per-machine:
            log file = /var/log/samba/log.%m
            # maximum size of 50KB per log file, then rotate:
            max log size = 50
    # ----------------------- Standalone Server Options ------------------------
    # security = the mode Samba runs in. This can be set to user, share
    # (deprecated), or server (deprecated).
    # passdb backend = the backend used to store user information in. New
    # installations should use either tdbsam or ldapsam. No additional configuration
    # is required for tdbsam. The "smbpasswd" utility is available for backwards
    # compatibility.
            security = user
            passdb backend = tdbsam
    # ----------------------- Domain Members Options ------------------------
    # security = must be set to domain or ads.
    # compatibility.
    # realm = only use the realm option when the "security = ads" option is set.
    # The realm option specifies the Active Directory realm the host is a part of.
    # password server = only use this option when the "security = server"
    # option is set, or if you cannot use DNS to locate a Domain Controller. The
    # argument list can include My_PDC_Name, [My_BDC_Name], and [My_Next_BDC_Name]:
    # password server = My_PDC_Name [My_BDC_Name] [My_Next_BDC_Name]
    # Use "password server = *" to automatically locate Domain Controllers.
    ;       security = domain
    ;       passdb backend = tdbsam
    ;       realm = MY_REALM
    ;       password server = <NT-Server-Name>
    # ----------------------- Domain Controller Options ------------------------
    # security = must be set to user for domain controllers.
    # compatibility.
    # domain master = specifies Samba to be the Domain Master Browser, allowing
    # Samba to collate browse lists between subnets. Do not use the "domain master"
    # option if you already have a Windows NT domain controller performing this task.
    # domain logons = allows Samba to provide a network logon service for Windows
    # workstations.
    # logon script = specifies a script to run at login time on the client. These
    # scripts must be provided in a share named NETLOGON.
    # logon path = specifies (with a UNC path) where user profiles are stored.
    ;       security = user
    ;       domain master = yes
    ;       domain logons = yes
            # the following login script name is determined by the machine name
            # (%m):
    ;       logon script = %m.bat
            # the following login script name is determined by the UNIX user used:
    ;       logon script = %u.bat
    ;       logon path = \\%L\Profiles\%u
            # use an empty path to disable profile support:
    ;       logon path =
            # various scripts can be used on a domain controller or a stand-alone
            # machine to add or delete corresponding UNIX accounts:
    ;       add user script = /usr/sbin/useradd "%u" -n -g users
    ;       add group script = /usr/sbin/groupadd "%g"
    ;       add machine script = /usr/sbin/useradd -n -c "Workstation (%u)" -M -d /nohome -s /bin/false "%u"
    ;       delete user script = /usr/sbin/userdel "%u"
    ;       delete user from group script = /usr/sbin/userdel "%u" "%g"
    ;       delete group script = /usr/sbin/groupdel "%g"
    # ----------------------- Browser Control Options ----------------------------
    # local master = when set to no, Samba does not become the master browser on
    # your network. When set to yes, normal election rules apply.
    # os level = determines the precedence the server has in master browser
    # elections. The default value should be reasonable.
    # preferred master = when set to yes, Samba forces a local browser election at
    # start up (and gives itself a slightly higher chance of winning the election).
    ;       local master = no
    ;       os level = 33
    ;       preferred master = yes
    #----------------------------- Name Resolution -------------------------------
    # This section details the support for the Windows Internet Name Service (WINS).
    # Note: Samba can be either a WINS server or a WINS client, but not both.
    # wins support = when set to yes, the NMBD component of Samba enables its WINS
    # server.
    # wins server = tells the NMBD component of Samba to be a WINS client.
    # wins proxy = when set to yes, Samba answers name resolution queries on behalf
    # of a non WINS capable client. For this to work, there must be at least one
    # WINS server on the network. The default is no.
    # dns proxy = when set to yes, Samba attempts to resolve NetBIOS names via DNS
    # nslookups.
    ;       wins support = yes
    ;       wins server = w.x.y.z
    ;       wins proxy = yes
    ;       dns proxy = yes
    # --------------------------- Printing Options -----------------------------
    # The options in this section allow you to configure a non-default printing
    # system.
    # load printers = when set you yes, the list of printers is automatically
    # loaded, rather than setting them up individually.
    # cups options = allows you to pass options to the CUPS library. Setting this
    # option to raw, for example, allows you to use drivers on your Windows clients.
    # printcap name = used to specify an alternative printcap file.
            load printers = yes
            cups options = raw
    ;       printcap name = /etc/printcap
            # obtain a list of printers automatically on UNIX System V systems:
    ;       printcap name = lpstat
    ;       printing = cups
    # --------------------------- File System Options ---------------------------
    # The options in this section can be un-commented if the file system supports
    # extended attributes, and those attributes are enabled (usually via the
    # "user_xattr" mount option). These options allow the administrator to specify
    # that DOS attributes are stored in extended attributes and also make sure that
    # Samba does not change the permission bits.
    # Note: These options can be used on a per-share basis. Setting them globally
    # (in the [global] section) makes them the default for all shares.
    ;       map archive = no
    ;       map hidden = no
    ;       map read only = no
    ;       map system = no
    ;       store dos attributes = yes
    #============================ Share Definitions ==============================
    [homes]
            comment = Home Directories
            browseable = no
            writable = yes
    ;       valid users = %S
    ;       valid users = MYDOMAIN\%S
    [printers]
            comment = All Printers
            path = /var/spool/samba
            browseable = no
            guest ok = no
            writable = no
            printable = yes
    # Un-comment the following and create the netlogon directory for Domain Logons:
    ;       [netlogon]
    ;       comment = Network Logon Service
    ;       path = /var/lib/samba/netlogon
    ;       guest ok = yes
    ;       writable = no
    ;       share modes = no
    # Un-comment the following to provide a specific roving profile share.
    # The default is to use the user's home directory:
    ;       [Profiles]
    ;       path = /var/lib/samba/profiles
    ;       browseable = no
    ;       guest ok = yes
    # A publicly accessible directory that is read only, except for users in the
    # "staff" group (which have write permissions):
    ;       [public]
    ;       comment = Public Stuff
    ;       path = /home/samba
    ;       public = yes
    ;       writable = yes
    ;       printable = no
    ;       write list = +staff
    • #15492
      Samba 설정법입니다. 아래 링크를 참조 하시고 보다 상세한 설정은 구글링해 보시기 바랍니다.
      http://www.server-world.info/en/note?os=Fedora_22&p=samba
    • #101693
      Fedora 34 기준으로 작성한 samba 설정 글이 업데이트 되어 해당 글에 링크를 남깁니다.
      파일 공유 samba 서버 구성 - 네트워크 파일 공유 - 삼바
영자님이 열씸이네요....
oracle vm 과 사투중...
앞으로 달라진 dnf5 시스템 및 group 설치 관련 부분
새로운 사이트 오픈 완료(Grand Opening)
감기조심, 즐거운 주말 보내세요.
binutils-2.24설치 문의
가입인사입니다~ ^^
리눅스 마스터 2급 합격했습니다!!ㅋㅋ
샌디스크 usb live 설치 문의입니다.
