외부에서 사내망의 메일서버로 메일을 보내면 다음과 같은 로그가 뜹니다.
게시판 질문게시판 외부에서 사내망의 메일서버로 메일을 보내면 다음과 같은 로그가 뜹니다.
  • This topic has 1개 답변, 2명 참여, and was last updated 8 years, 11 months 전에 by
    난해주님. This post has been viewed 2235 times
  • #13695
    둥둥이
      게시글41 댓글32 총합73
    @seojh1431
    22:59:33.283272 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags , seq 3787143744, win 5840, options [mss 1460,sackOK,TS val 3591989130 ecr 0,nop,wscale 7], length 0
    22:59:33.293312 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags [.], ack 2918209589, win 46, options [nop,nop,TS val 3591989140 ecr 868967806], length 0
    22:59:33.311039 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags [.], ack 56, win 46, options [nop,nop,TS val 3591989158 ecr 868967823], length 0
    22:59:33.311096 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags [P.], seq 0:23, ack 56, win 46, options [nop,nop,TS val 3591989158 ecr 868967823], length 23
    22:59:33.323082 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags [P.], seq 23:69, ack 182, win 46, options [nop,nop,TS val 3591989170 ecr 868967835], length 46
    22:59:33.362559 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags [P.], seq 69:100, ack 227, win 46, options [nop,nop,TS val 3591989210 ecr 868967875], length 31
    22:59:33.379347 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags [P.], seq 100:106, ack 272, win 46, options [nop,nop,TS val 3591989226 ecr 868967892], length 6
    22:59:33.390953 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags [P.], seq 106:1296, ack 317, win 46, options [nop,nop,TS val 3591989238 ecr 868967903], length 1190
    22:59:33.441273 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags [P.], seq 1296:1299, ack 317, win 46, options [nop,nop,TS val 3591989288 ecr 868967953], length 3
    22:59:33.484143 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags [P.], seq 1299:1305, ack 362, win 46, options [nop,nop,TS val 3591989331 ecr 868967996], length 6
    22:59:33.495644 IP 192.168.1.21.50275 > 125.209.238.137.25: Flags [F.], seq 1305, ack 424, win 46, options [nop,nop,TS val 3591989343 ecr 868968008], length 0
    여기서 [nop,nop,TS val 3591989140 ecr 868967806], length 0 가 무슨 의미입니까?? 특히 nop, TS val, ecr 이 무슨 의미인지 궁금합니다.
    • #15621
      윈도우 메일 서버인가요?? 이런 로그에 대한 경험이 없어서 뭐라 드릴 말씀은 없습니다만
      TS의 의미는 TCP timestamp 의미로 추측 합니다. (형식이 그런듯)
      nop는 none option의 의미인 것 같고 ecr은 뭔지 잘 모르겠습니다.
      뭔가 tcp 설정에(방화벽) 문제가 있을 것으로 추측합니다.
가입 인사 드려요
[tip-tech] firefox timeout 오류에 따른 수동 설치 방법
안녕하세요 월요일 입니다
페도라 14 무선랜 잡는 방법좀요!
Rocky Linux 내용 관련 오픈소스 인프라 세미나 정보
Fedora17에서 18로 업글
Fedora14 설치하신분 스샷좀 올려주셔요~~
오랜만에 인사 드립니다
adobe flash player 이거 제대로 설치하는방법 있나여?
