페도라 11, 12, 13 지원되는 젠 4.0 릴리즈 되었습니다 ( 2010년 4월 3일 현지시간)
게시판 새소식/정보 페도라 11, 12, 13 지원되는 젠 4.0 릴리즈 되었습니다 ( 2010년 4월 3일 현지시간)
  • This topic has 4개 답변, 3명 참여, and was last updated 14 years, 12 months 전에 by
    ELem. This post has been viewed 1271 times
  • #16502
    젠4.0이 릴리즈 되었습니다.
    눈에 띄는 것중의 하나는 페도라 11, 12, 13 배포판을 위한 yum 설치가 된다라는 겁니다.
    페도라 사용자라는 것이 갑자기 뿌듯해집니다. ㅎㅎ
    주소는 http://wiki.xensource.com/xenwiki/Xen4.0 입니다.
    Packages required for building from source
    Packages
    required to build Xen 4.0 from source on Fedora 11, 12, or 13, in
    addition to all the usual development tools and libraries:
    yum groupinstall "Development Libraries"
    yum groupinstall "Development Tools"
    yum install transfig texi2html libaio-devel dev86 glibc-devel e2fsprogs-devel gitk mkinitrd iasl xz-devel bzip2-devel
    nstallation from source
    Xen 4.0 source code mercurial (hg) repository and changelog: http://xenbits.xen.org/xen-4.0-testing.hg
    You can get Xen 4.0 with mercurial using the following command:
    hg clone http://xenbits.xen.org/xen-4.0-testing.hg
    Alternatively you can download the Xen 4.0.0 source tarball from http://www.xen.org/products/xen_source.html
    If
    you want to install only the new Xen 4.0 hypervisor and tools, and use
    your previous dom0 kernel, or build your own custom dom0 kernel:
    cd xen-4.0-testing.hg
    make xen
    make tools
    make stubdom
    When the compilation process finishes you'll have the binaries in "dist/" directory ready for installation:
    make install-xen
    make install-tools
    make install-stubdom
    And
    then compile your chosen new dom0 kernel, or use your existing dom0
    kernel, and update grub.conf to use the new Xen hypervisor.
    You can also compile Xen 4.0 together with the new default pvops dom0 kernel (2.6.31.x):
    make world
    This will download the pvops dom0 kernel from Jeremy's xen.git repository during the build process.
    Later if you want to track the changes made (patches added) to xen-4.0-testing.hg repository do this to update the tree:
    make clean
    hg pull
    hg update
    hg log | less
    #verify you see the latest changes in the log
    <and continue as above to build and install it>
    Example grub configuration for Xen 4.0 with a pvops dom0 kernel
    Example entry for Xen dom0 /boot/grub/grub.conf:
    title        Xen 4.0, Linux kernel 2.6.32.11
    root (hd0,0)
    kernel /xen-4.0.gz dom0_mem=1024M loglvl=all guest_loglvl=all
    module /vmlinuz-2.6.32.11 root=/dev/sda1 ro nomodeset
    module /initrd.img-2.6.32.11
    Obviously
    you need to modify the example grub.conf entry above to have correct
    values for your setup, especially for the root= parameter. Check the
    existing grub.conf entries and make the new entry similar to them.
    Binary packages
    There are no binary packages available yet.
    Fedora 12 users can grab Xen 4.0.0 src.rpm from https://fedorapeople.org/~myoung/dom0/src/ , direct link: https://fedorapeople.org/~myoung/dom0/src/xen-4.0.0-0.7.fc12.src.rpm . You can then use "rpmbuild -bb" to build binary rpm packages on your system.
    Tutorials to install Xen 4.0
    No tutorials available yet.
    • #16594
      한번설치를 해봐야 겟네요 xen은 아직 안써봐서리 ㅎㅎ
    • #16595
      한번쯤은 설치해볼 가치가 충분히 있습니다.
      저는 이제는 공부/실험용으로만 사용하고 있고, 평상시에는 그냥 virtualbox를 사용중입니다. ^^
    • #16596
      버추얼박스가 vmware에 비교해서 충분히 안정적이며 기능도 훌륭하고
      일단 가벼워서 저도 항상 버추얼박스만 쓰는데
      인베인님말씀처럼 XEN 설치나 사용은 해봐야할듯하네요
    • #16597
      yum으로~~~ 소스 컴파일 준비가 되는군요[..]
      Xen 4.0 써볼까요..ㅎ
Freetype-2.6+cairo-1.14.2 Fedora22 버전(Ugly randering gtk3 fix)
[Tip]Nvidia Driver 설치 후 Gnome-Shell 티어링 패치시 opengl 라이브러리 링크 방법
감사드립니다
페도라14 관련 문의입니다.
자답...
노트북 절전모드 막는 방법?
전설의 T420 F35 사용
페도라 15 릴리즈 Countdown 배너가 나왔습니다.
LVM 쓰시는분들 F13 설치할때 파티셔닝에서 자주 죽지 않나요?
ffmpeg 2.8 패키지입니다. (수세 스타일 빌드)
